nissan x-trail sinchronization
neriuks007
Post by neriuks007 » Tue Jun 10, 2014 5:35 am
hello,i have nissan x-trail 2003 2,2diesel ,yd22ddti.i can not start after engine replace,common rail presure ok,i think that trouble is sinchronization camshaft crankshaft.please in picture
Chris C Stahl
Re: nissan x-trail sinchronization
Post by Chris C Stahl » Tue Jun 10, 2014 1:48 pm
Have you checked the camshaft wave form against known good
Post by KimAndersen » Tue Jun 10, 2014 5:39 pm
Are there any diagnostic trouble codes present now !!!
Kim
Chris C Stahl
Post by Chris C Stahl » Thu Jun 12, 2014 7:23 pm
So what fixed the problem :?:
Post by Robski » Thu Jun 12, 2014 9:42 pm
Chris C Stahl wrote:So what fixed the problem :?:
Who said it was fixed ?
Looking at that capture compared with one I've seen the timing is out.
Chris C Stahl
Post by Chris C Stahl » Thu Jun 12, 2014 10:53 pm
What does a good capture look like :?:
Post by Robski » Thu Jun 12, 2014 11:19 pm
Chris C Stahl wrote:What does a good capture look like :?:
in time :!:
Not my file to share.
trutrail
Post by trutrail » Sun Jun 15, 2014 7:35 am
We have done several of these problems. Do you have a fault code for CMP CKP synchronization? If so it will almost certainly be timing chain related. Nissans are renowned for timing chain stretch. When this reaches a certain point the Cam and Crank loose their unity and hence the code. You can get the same problem occur with variable valve timing if the correct tools and procedures aren't followed precisely. Good luck.
neriuks007
Post by neriuks007 » Tue Jun 17, 2014 11:27 am
the good sinchronization.
Chris C Stahl
Post by Chris C Stahl » Tue Jun 17, 2014 3:05 pm
Thanks I always like to hear the end of the story :|
