can i do relative compression with a synch?
blake
Post by blake » Fri Jun 06, 2014 11:22 pm
I had a vehicle that had a dead cylinder and a weak cylinder that showed up during the relative compression test using the pico diagnostics software. my question is can i add a synch cylinder to that test so i can use the firing order to determine the dead cylinder and the weak cylinder? the vehicle had plug wires so i just wanted to use my inductive pickup probe for my synch cylinder.
Any help is appreciated,
Blake
volrem
Re: can i do relative compression with a synch?
Post by volrem » Sat Jun 07, 2014 7:21 am
Use Picoscope (not Picodiagnostics) and measure starter current with amp clamp. Sync with one of cylinders.
