PicoScope Beta 6.9 Waveform Library Browser
tode
Re: PicoScope Beta 6.9 Waveform Library Browser
Post by tode » Sun Sep 07, 2014 6:27 pm
If possible, I wanted to ask how to tell if the upload of the waves, from my PC,
are completed successfully, I have had several problems with three different PCs even if the files were only 6 Mb upload could not do, now I uploaded a single waveform with 500Kb of space and I've had no error messages , I have other waves to be loaded if they are sure they are successful ..... I continue. :D
Post by Steve Smith » Tue Sep 09, 2014 8:25 am
Hi Tode and thank you again for all your uploads.
To confirm your uploaded waveforms are successful, from the "Home" screen select the "My Waveforms" option to view all your personally uploaded waveforms.
Regarding file sizes, we will continue to discuss how we can improve upon the restrictions in place given the original file size is not always an indication that an upload will be successful, given the additional information that is saved above the original file size.
I hope this helps
Take care.......Steve
tode
Post by tode » Tue Sep 09, 2014 7:14 pm
Ok, I understand. Great system, very well done.
volrem
Post by volrem » Wed Oct 01, 2014 6:06 am
One suggestion:
Could you add ID number to each waveform and make it searchable. So when I upload waveform and want to share it with someone I just tell him/her ID and he/she can search for it. Would be much quicker that making selection by car/make ....
Post by Steve Smith » Wed Oct 01, 2014 8:42 am
Hello Volrem, great idea thank you.
I will feed this onto the engineer responsible for the waveform library.
Take care......Steve
volrem
Post by volrem » Wed Oct 01, 2014 12:51 pm
One more thing.
Search gives no results if I enter partial engine code.
For example i want to search all D5244 engines (T;T2;T4;T5;T15 and so on).
Even if I search D5244* then no results are displayed.
Please add/fix this.
Post by Steve Smith » Thu Oct 02, 2014 10:31 am
Hello Volrem, thank you for the feedback again
It would appear we need to full engine code to display any relevant waveforms.
I can see how a partial code may help and will add this to your previous suggestion placed with the engineers.
Many thanks again, take care......Steve
Post by liviu2004 » Sun Apr 23, 2017 6:15 pm
Are waveforms saved with newer Pico software not backwards compatible with older software, at least for View? Tried today to load a waveform and got an error about loading from a newer software.
PicoKev
Post by PicoKev » Sun Apr 23, 2017 10:40 pm
Picoscope software is not capable of loading or viewing a file that has been saved in a newer version of the software.
This does not present a user from using the file, as the latest Release and Beta versions are always available (Free Of Charge) from the download page of the automotive site: https://www.picoauto.com/downloads
Beta versions will install separately as a stand alone program with a separate shortcut icon on your desktop.
The only time you will have an issue is if you are still running Win. XP as the newer software is not compatible with legacy software.
Hope that helps,
Kev.
Post by liviu2004 » Mon Apr 24, 2017 3:35 am
Thanks for answer, I see no point in downloading a newer software, which is not compatible with my scope, just to uninstall it again when I need to run the scope. :roll:
However, your answer clarifies my question.
