Misfire/hesitation under load
pesky164
Post by pesky164 » Thu Apr 17, 2014 5:39 pm
20140417-0004.psdata
Cylinder 4
(854.49 KiB) Downloaded 351 times
20140417-0003.psdata
Cylinder 3
(891.85 KiB) Downloaded 394 times
20140417-0002.psdata
Cylinder 1
(858.92 KiB) Downloaded 375 times
20140417-0001.psdata
Cylinder 2
(856.34 KiB) Downloaded 389 times
Hi, as stated in title, I have a misfire/hesitation under heavy load, feels like a plug/lead breaking down. I've checked the lambda - ok, also no fault codes, so thought I'd get the scope out. Attached are the four patterns, obtained by using the coil extension lead & HT pickup lead on channel A & channel B on the coil trigger. Not the pattern I was expecting on any cylinder but also worried about the interference on cylinder 3. I swopped coils & spark plugs but interference remained. I haven't checked the wiring back to the ECU & haven't checked the primaries with the scope yet, just thought I'd open up conversation now.
Vehicle: Fiat Marea 1800cc 16v 2001 Hitachi injection
Cheers in advance... :D
Paul :mrgreen:
Re: Misfire/hesitation under load
Post by KimAndersen » Fri Apr 18, 2014 2:28 pm
Hi there
To start with I would use some basic diagnostic skills - such as whether the ignition coils are getting power and ground and finally I would see if the coil on plug are receiving a good trigger signal from the ECU.
A fairly easy way to check the functions of all the ignition coils in one simpel test - is to use a current clamp around the common feed supply to the coils. The ignition coils are getting power from the fuel relay - so if you can find this relay it shouldn´t be difficult to make this test.
Kim
pesky164
Post by pesky164 » Sat Apr 19, 2014 4:50 pm
Cheers for the quick reply, I'll check current draw for each coil & let u know...
Having said that the fault seems to have temporarily disappeared.... :roll:
